Dry recordings
0 Members and 1 Guest are viewing this topic. Read 3779 times.
matevana
Dry recordings
« on: 20 Jan 2022, 05:56 pm »
Can anyone recommend a jazz track or album that sounds as if it were recorded in a very dry room?  I'm looking for material with almost no apparent echo or room reflections, as anechoic sounding as possible. I realize this is rare (often undesirable) but I'd like it for testing purposes.  Thanks in advance!
I.Greyhound Fan
Re: Dry recordings
« Reply #1 on: 20 Jan 2022, 07:10 pm »
Give a listen to just about anything from soundliason
https://www.soundliaison.com/
Also ECM recordings.
This album by Tord Gustavsen is worth a listen
https://www.allmusic.com/album/the-ground-mw0000736311
matevana
Re: Dry recordings
« Reply #2 on: 20 Jan 2022, 07:35 pm »
Thanks!  We listen to a lot of the same things. I currently own 4-5 of the one-mic recordings from Sound Liaison. The albums I have are mostly live recordings and the venues take on more of a hall-like character (you can really hear this on the applause at the end of each track). Well recorded tracks for sure though.  I also own The Ground from TG so I'll go back and check that one out. In my mind, I'm thinking maybe something like a jazz trio recorded in a small neutral room, with each instrument closely mic'd and no ambient mics used?  It's proving hard to find.
Re: Dry recordings
« Reply #3 on: 21 Jan 2022, 02:45 am »
To me it sounds a close-up recording but the performances are superb first class, one of my favor Jazz albums:
« Last Edit: 21 Jan 2022, 05:11 am by FullRangeMan »
I.Greyhound Fan
Re: Dry recordings
« Reply #4 on: 21 Jan 2022, 03:30 am »
Also check out Blue Coast recordings.  Usually single mic.
Anouar brahem Astounding Eyes or Rita ECM recording.  Dead silent background.
matevana
Re: Dry recordings
« Reply #5 on: 21 Jan 2022, 09:51 am »
This is good. Thanks for the suggestion.
