SP3 - lip sync limited to 39 ms - can't factory reset
0 Members and 1 Guest are viewing this topic. Read 1010 times.
Grit
  • - Garrett
Help.
My lipsync on inputs is limited to 39ms (not the 255 ms listed in the manual). in addtion, I can't seem to perform a reset. Help please!
- Garrett
Grit
  • - Garrett
Re: SP3 - lip sync limited to 39 ms - can't factory reset
« Reply #1 on: 21 Jan 2022, 08:09 am »
I managed a factory reset using the web interface. I can now move lipsync to 44ms. What gives?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 21 Jan 2022, 12:44 pm »
Email Adam - [email protected]
james
Grit
  • - Garrett
« Reply #3 on: 22 Jan 2022, 06:18 pm »
Thanks James. At a guess, I'd emailed Mike Pickett. Thanks for the new point of contact. I'll email right now.
