El34 tubes
0 Members and 1 Guest are viewing this topic. Read 3319 times.
Kw6
El34 tubes
« on: 17 Jan 2022, 07:09 am »
Hey everyone!
Are JJ El34 tubes reliable? I read they are best current production El34s? Thanks!
Re: El34 tubes
« Reply #1 on: 17 Jan 2022, 07:15 am »
JJ's are not particularly reliable.  IME, the best current production EL34 tubes are the Psvane EL34-PH.
musicdre
  • reality is the base
    • art site
Re: El34 tubes
« Reply #2 on: 17 Jan 2022, 12:18 pm »
do you know what the PH refers to in EL34-PH?  thanks
Markwatkiss
Re: El34 tubes
« Reply #3 on: 17 Jan 2022, 03:14 pm »
Before you make the leap I was not impressed with the EL34 PH.Of all the EL 34’s I’ve owned the Genalex Golden Lion KT 77 is the most accomplished.Covers all the bases in presenting a coherent sound stage.
Price for performance is hard to beat.
Re: El34 tubes
« Reply #4 on: 17 Jan 2022, 03:37 pm »
according google Philips Holand.
Re: El34 tubes
« Reply #5 on: 17 Jan 2022, 05:01 pm »
Haha, that's funny.  Because the Gold Lion KT77 is one of the few pentodes I really dislike the sound of.
So I guess the lesson is that there's no agreement :P
DaveC113
  • ZenWaveAudio.com
Re: El34 tubes
« Reply #6 on: 17 Jan 2022, 05:44 pm »
Agreed, GL KT77 is as good as or better than many NOS tubes. Not as reliable but also not as expensive.
Kw6
Re: El34 tubes
« Reply #7 on: 17 Jan 2022, 06:00 pm »
I do have GL KT77 as I bought them as they get good reviews on the web. When I put them in my integrated they sound ok over the stock Pavane private lable black base for Cayin. Then I have been listening to other amps and then come back to Cayin and it was bright. Put back Psvane black base and is better. I don't like GL 12au7 either also bright. For El34 I only try new production like Mullard and Tungsol. They are better to my ears. Hoping Psvane metal base cut above the rest.
Kw6
Re: El34 tubes
« Reply #8 on: 17 Jan 2022, 06:02 pm »
I agree with you Tyson!😊
Kw6
Re: El34 tubes
« Reply #9 on: 17 Jan 2022, 06:02 pm »
Thanks for all your replies!😃
rotarius
Re: El34 tubes
« Reply #10 on: 17 Jan 2022, 07:00 pm »
JJ power tubes still have a high failure rate so a lot of dealers won't carry them.  If you get them thoroughly tested, they should be fine.  Eurotubes seems to have a special relationship with the factory and might be getting better stock than others.  Great customer service.  The one failure I had from them was because of an amp issue and not the tube itself.  Yes, I liked the sound quality of the el34 family with the 6ca7 being the ones I liked best.  Way better than EH 6ca7.  The E34L seems to be the most rugged of the bunch and the KT77 the most extended.
The tubes that are very reliable and surprisingly good sounding were the EH el34.  I liked them in my Jolida 3502.
AllynW
Re: El34 tubes
« Reply #11 on: 17 Jan 2022, 07:51 pm »
I use Mullard EL-34's in my Jolida JD-1000A.  After changing out the stock Chinese tubes that came with the Jolida, I have never felt the need to try other EL-34 tubes.  I only get tubes from Upscale Audio which was a learned lesson.
Kw6
Re: El34 tubes
« Reply #12 on: 18 Jan 2022, 06:08 am »
Yes I saw the reviews on Eurotubes. They probably test regularly and throw the duds away! Yeah read EH has good reliability and sounds decent!
Kw6
Re: El34 tubes
« Reply #13 on: 18 Jan 2022, 06:09 am »
Upscale is very reputable! Thanks for sharing!
