NuPrime IDA-8 Integrated Amp/DAC - SOLD
0 Members and 1 Guest are viewing this topic. Read 534 times.
Phil A
« on: 15 Jan 2022, 04:04 am »
SOLD
$650 including shipping (in the original box) and insurance to the continental US.  Cashier's check, Postal money order or Zelle free.  PayPal add $25  Unit just returned from NuPrime repair for a minor display issue (display board was replaced).  Only mark that I could find is glue residue on the bottom of one foot (not the original owner and assuming the piece came off and was glued back on).  It is not visible as it is underneath.  Received light use in an office system and I simplified the system with Vanatoo (Transparent One Encore) powered speakers/DAC.  Have a Synergistic Research Red Fuse that is negotiable with the deal ($90 retail - e.g. https://www.vhaudio.com/synergistic-research-red.html) for a bit more.
Specifications:
Inputs:
1 x USB PCM / DSD Digital (PCM up to 384kHz & DSD up to DSD256)
1 x Coaxial Digital S/PDIF (PCM up to 192K supporting DoP format DSD64)
1 x Optical Digital S/PDIF (PCM up to 192K supporting DoP format DSD64)
1 x Bluetooth or WiFi receiver device (optional)
1 x Analog Stereo RCA (analog input will be digitized)
Outputs:
1 x pair of stereo speaker (binding posts) output
1 x pair of stereo RCA (2V*), variable (volume controlled) output, full range
USB Sampling Rates:Â 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz and DSD 2.8MHz, 5.6MHz, 11.2MHz
S/PDIF Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz, 384KHz (Coaxial)
Bluetooth sampling rate: 48kHz
Bit Resolution: 16-32-bits
Power output: 100W x 2 @ 8 Ohms; 100W x 2 @ 4 Ohms
THD+N: 0.005%
SNR: 95dB
Peak Output Power: 280w
Frequency Response: 10Hz to 50kHz
AC voltage: (90VAC~130VAC // 210VAC~ 250VAC) With Voltage Select Switch
AC Fuse: Slow-blow, 3A, 250VA
« Last Edit: 24 Jan 2022, 09:27 pm by Phil A »
