DAC DAC Power Supply Info
0 Members and 1 Guest are viewing this topic. Read 4719 times.
joessportster
  • Set & Single Driver Bliss
« on: 13 Jan 2022, 06:35 pm »
Does anyone have the specs on the Power supply ?  The diagram on the site is low resolution and I can not make it out. A Pic of a Power supply with all the info showing would work. Most PS will have a side that tells you the input and output info as well as the connectors polarity
I bought a DAC DAC TL,  and No PS was included in the box, Hoping some one here can help with the info
Thanks Joe
orchardaudio
    • Orchard Audio
Re: DAC DAC Power Supply Info
« Reply #1 on: 22 Feb 2022, 12:56 am »
Thanks Joe
It is 12V 6W power supply. This will work:
https://www.digikey.com/en/products/detail/cui-inc/SMI6B-12-4-P5/10264699
joessportster
« Reply #2 on: 22 Feb 2022, 01:22 am »
Thank you sir Have one now...............Dac is playing as I type this :icon_lol:
I should have updated the thread  :duh:
