SP 1.7 randomly resetting
0 Members and 1 Guest are viewing this topic. Read 1983 times.
thomaspf
« on: 30 Mar 2005, 05:18 am »
Hi,
I guess this is a question for James. I had my 1.7 in use most of the day today and in the evening it started to reset the DSP at random intervals of about 5min. It came right back after displaying the DSP version etc. but I suppose you should be able to have the unit powered up 24 by 7.
The 1.7 sits at the top of my audio shelf so there is plenty of ventilation.
What do you suggest I do?
Cheers
    Thomas
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 30 Mar 2005, 12:11 pm »
Hi Thomas,
New one on me - I will check with Mike in Engineering on that one.
james
thomaspf
« Reply #2 on: 30 Mar 2005, 07:27 pm »
Thank You James,
I turned it back on this morning and so far it is fine. I will let it run for the day and see if this comes back.
Cheers
   Thomas
thomaspf
« Reply #3 on: 30 Mar 2005, 10:26 pm »
Ups,
it just reset itself again, so this now seems an established pattern after a couple of hours of warm-up.
Let me kno what you find out from service.
Cheers
   Thomas
« Reply #4 on: 1 Apr 2005, 12:50 am »
Hi Thomas,
Checked with engineeriing and repair and this is a first. We should get it back and have a look at it for you.
james
cervelo123
Re: SP 1.7 randomly resetting
« Reply #5 on: 9 Apr 2016, 01:31 am »
I'm having the same problem that my processor is resetting. Over the course of a couple of weeks, I've contacted Tech Support three times but I haven't gotten a response back.
Doe anyone know how to resolve the problem?
Thanks.
