Speaker stand recommendations
0 Members and 1 Guest are viewing this topic. Read 2173 times.
chilly1
« on: 13 Jan 2022, 01:57 am »
Anyone have suggestions for a set of speaker stands?
They will be for a pair of BMR Philharmonics
weatherman1
Re: Speaker stand recommendations
« Reply #1 on: 13 Jan 2022, 06:33 am »
Audio Advisor sells Pangea stands.  I bought a pair of the 19in. model.  Solid tubular steel and two of the three  support tubes can be filled for added stability.  Back tube is used to run speaker wire.  If memory serves it comes with two sizes of top plates but the BMR need the big plate.  Easy assembly and just a nice height for the TALL Philharmonics.  Sold on Amazon through Kraft Street Audio which the location in Grand Rapids, MI of Audio Advisor.
Doublej
« Reply #2 on: 13 Jan 2022, 01:01 pm »
Monoprice Monolith series too.
iowa
  • Brennan B2>TDAI 1120>Sierra 1> T-Zero(2)
« Reply #3 on: 13 Jan 2022, 02:11 pm »
+1 on the Monolith by Monoprice. Inexpensive, easy to assemble, fillable columns and sturdy. They are what I use for my Ascend Acoustics Sierra's.
« Reply #4 on: 13 Jan 2022, 02:14 pm »
Recommend sizing them so that tweeter is at listening ear height.
Poultrygeist
« Reply #5 on: 27 Jan 2022, 12:44 pm »
I found these on Amazon which are C&C. The top plates on most stands are too small but you can easily DIY one that fits your speakers. I drilled a couple of holes in the metal plate and used screws from the bottom.
