Klipsch KG-5.2
0 Members and 1 Guest are viewing this topic. Read 953 times.
greggstone
Klipsch KG-5.2
« on: 8 Jan 2022, 11:21 pm »
Has anyone had Danny upgrade a pair of Klipsch KG-5.2?
Be interested in your thoughts?
cedman1
Re: Klipsch KG-5.2
« Reply #1 on: 11 Jan 2022, 02:36 am »
I had a pair of KG 4.2 a while back.  Out of curiosity I opened them up and the first thing I noticed was zero "0" bracing unless you count the 1/4 round rods that were used along the edges.  I would be interested to see if anyone did send those in as well.
Hobbsmeerkat
Re: Klipsch KG-5.2
« Reply #2 on: 11 Jan 2022, 04:13 am »
I don't believe anyone has sent one in yet.
But no surprise on the lack of bracing, the Forte III are the same way and that's probably the first things I would recommend doing to them.
Here's how Tyson and Danny braced the Forte III:
https://www.audiocircle.com/index.php?topic=166996.msg1773331#msg1773331
I believe the Cornwall III and IV do have some bracing between the mid horn and woofer, but it's still quite minimal.
