acoustic foam for mid/high absorbtion?
0 Members and 1 Guest are viewing this topic. Read 1439 times.
michaelv
« on: 29 Mar 2005, 08:13 pm »
Hi,
 I'm new to the forum and i have questions on acoustic panel.
 I see acoutic foam from foambymail.com  with reasonable prices. So i'm planning to install  6 pannel (2'x4'). However, i don't want to stick these foams on the wall . Instead, i want to mount  8 of 12"x12" on the some sort backing board or wood to create 2'x4' panel, then hang this on the wall with a hook or somthing. Does this will affect the efficiency of the acoustic ?
 I know that fiberglass is better, but i am not handy in wood making :), so  i want something available to use. I can get a good deal on Ebay for this as well.
thanks for your time.
BradJudy
« Reply #1 on: 29 Mar 2005, 08:57 pm »
I would expect something like foamcore would work well for this.  It should be available in any hobby or art supply in 24"x36" sheets.  You could use something like 1/8" or 1/4" hardboard or plywood instead.  I don't know what would be best acoustically.
