Speaker on Sub
0 Members and 1 Guest are viewing this topic. Read 1380 times.
konut
Speaker on Sub
« on: 3 Jan 2022, 05:28 pm »
I know it is generally frowned on  :( to put a monitor on a sub. It would simplify greatly my setup if I did so in my small room. Are there any solutions (materials to put between speaker and sub) that would offer isolation and reasonably acceptable SQ?
Re: Speaker on Sub
« Reply #1 on: 3 Jan 2022, 05:37 pm »
Herbies Audio Lab has some excellent isolation devices that work great for this.
konut
Re: Speaker on Sub
« Reply #2 on: 3 Jan 2022, 06:05 pm »
I have submitted a request asking which product they recommend on their website.
Re: Speaker on Sub
« Reply #3 on: 5 Jan 2022, 01:29 pm »
Isolation is not the main objection.  Bass is best generated in a corner or along the wall, mids/highs are best reproduced away from walls/corners.  Perhaps you can try DSP to compensate.  Most isolation products are far too stiff (not compliant for a given weight) to offer isolation.
Best option would be to use a larger, less square, insulated, and dedicated room.  Or simply switch to headphones if your room is so small you can't separate monitors from subwoofers.
