Evolution PA 5.2 AVM preamp for sale $3150
0 Members and 1 Guest are viewing this topic. Read 533 times.
mcallij1
« on: 31 Dec 2021, 06:41 pm »
The PA5.2 offers a large variety of connectivity: The headphone input may alternatively be used as an input for external players.
The PA5.2 is a very versatile preamplifier: 5 line inputs, a front input and 3 slots for the optional plug-in modules connect it to any source. Poweramps can be connected via RCA Cinch or XLR alike. Active subwoofer may connect to the processor in/out. Comfortable menu functions allow an individual configuration of the PA3.2 according to your personal likings (input names, sensitivity) etc.). The sophisticated handling concept makes it easy to use. This way the PA5.2 will provide pure, long lasting joy of listening at all times.
Specifications
Tube output stages equipped with ECC83 (12 ax7a), balanced mode
Regulated high voltage generator independent from AC mains for supply of the tubes
5 line inputs (one XLR), 1 processor in/out, 2 Pre Amp outputs (cinch and XLR)
Headphone output, switchable as front-in
3 slots for: Phono module (MM and MC), tuner module, USB DAC module with
192 kHz/24 bit upsampling (USB, SPDIF opt. and coaxial)
Input specific tone control and parametric loudness with bypass-function
Blue graphic display dimmable
RC3 included
Menu functions (i.e adjustable input sensitivity, individual input naming, display settings and many more)
Dimensions (W x H x D) 430 x 130 x 370 mm
Weight approx. 17.6 lbs
