0 Members and 1 Guest are viewing this topic. Read 3978 times.
I have an EL84 based OddWatt Podwatt...Any thoughts on the feasibility and/or possible issues?Thanks,Mike
Also, what impedance are your headphones? Most hifi amps are designed to drive 8 or 16 ohm speakers, so if your headphones are 32 ohm or 200 ohm, you might need to make adjustments to your OPT''s.
Call or email Bruce? He is a frequent visitor here:Best, Alan
I'll try him on DIY audio projects, thanks.
Unlike AC, I couldn't find a member list or PM ability.
Mike, I should have mention that he goes by gofar99. If you created a profile you can use the following link to PM him. https://diyaudioprojects.com/Forum/memberlist.php?mode=viewprofile&u=56Best, AlanI sent him a PM too
Have you taken a look at https://wooaudio.com/ instead of converting an amp?
I have been able to listen to headphone amps from Swan Song Audio since they are here in Tulsa. So far their amps come closest to what I'm looking for. They are working on developing two new headphone amps, one SS and one tube, for Axpona. I've listened to the prototype SS and it is very promising. Tony is still tweaking on it to get the noise floor to zero. I'll be able to hear the tube version when it's close to ready. I'm strongly leaning toward Swan Song Audio.
Mike,I would think with that type of line of communication to a local source, it'll be well worth the wait. Possibly you can influence the build/evolution of the product as well.good luck!Ron
Quicksilver..Has a wonderful HP amp for around $1,000..http://quicksilveraudio.com/products/headphone-amplifier/
