Sell your Gaia IIs?
0 Members and 1 Guest are viewing this topic. Read 2406 times.
radarnyc
Sell your Gaia IIs?
« on: 24 Dec 2021, 01:11 pm »
Hi all
I have the X5s with their standard feet/spikes. Is there anyone here that would like sell their Gaia IIs for whatever reason?  i could do $400 and send you my feet/spikes.
geerock
Re: Sell your Gaia IIs?
« Reply #1 on: 24 Dec 2021, 02:29 pm »
Hi all
Check out Herbies Audio Labs.  Save money.  Same results....or better.
morganc
« Reply #2 on: 24 Dec 2021, 03:47 pm »
Which Herbies would you recommend for X-3’s on hardwood floors?
geerock
« Reply #3 on: 24 Dec 2021, 04:26 pm »
I would call Herbies for the best suggestion for your situation.  But off hand, if you want to keep your spikes I would suggest the Cone / Spike gliders.  Or, if no spikes, the Giant Fat Gliders which is what I use.  Both give you the benefit of being able to easily slide your speakers into place if you wish to move them to the wall after a listening session; or for easy adjustment.  BTW, I had the Gaia's and sent them back to Amazon and saved a chunk of cash.  Both did a nice job of isolation but I could hear no difference between the two products.
Mariusz Uszynski
« Reply #4 on: 24 Dec 2021, 05:19 pm »
Did you try Crutchfield, they sell them for $349.99can.I have Gaia III on my speakers and sub and love them.
https://www.crutchfield.ca/shopsearch/gaia_II.html
kayakerf
« Reply #5 on: 24 Dec 2021, 06:42 pm »
That price is for 1 set for 1 speaker. You'd need two - which is where it starts adding up...
Mariusz Uszynski
« Reply #6 on: 24 Dec 2021, 08:33 pm »
I'm sorry, I have forgotten.I paid for my Gaia III $250(tax in)-sub, then $500(tax in)-speakers.
« Last Edit: 26 Dec 2021, 03:43 pm by Mariusz Uszynski »
morganc
« Reply #7 on: 26 Dec 2021, 03:37 pm »
Cool. I’ll get the gliders too for the X3’s.
