0 Members and 1 Guest are viewing this topic. Read 4345 times.
I have a Panasonic 9000 in my main UHD system. Had an Oppo 203 before that and unless one needs the physical disc formats the Oppo does (e.g. SACD, DVD-A), the Panasonic is better in every way. I moved the Oppo 203 to a spare room where I had my old UHD TV and then sold the 203. For what I sold it for, I bought two Panasonic 820s, one for that spare room and one for the main system (have a music server and DAC and won’t ever use the Panasonic for audio - had an Oppo 103D in there which I moved to another spare system).
https://www.crutchfield.com/S-Ap9TBshQQ83/p_133UB820K/Panasonic-DP-UB820.html?XVINQ=DST&XVVER=30V&awcp=&awcr=386642029572&awdv=c&awkw=&awmt=&awnw=g&awug=1017856&gclid=EAIaIQobChMIpoGW6Lzp9AIVe2xvBB2ZZgscEAAYASAAEgLAf_D_BwEscratch and dent 820 for $450
So I guess the big question for me is - is the 9000 any better for video only purposes? Should I pocket the $500 price difference and get the 820?
Guys,I am updating my HT for the first time in 8 + years and I am trying to spend wisely. To watch movies I have been using JRiver on an HTPC + NAS. I need to update my HTPCs as they are old insufficient to play UHD material.So I think I have two options:Option 1: Get a new HTPC, connect it to my Denon AVR-3700 and NASOption 2: Get either a Panny 820 or 9000 and connect it to my Denon AVR-3700 and NASIs this correct?If so, it sounds like the much cheaper option is to go the Panny 820 way...Thoughts?Regards,George
Geroge - think the 820 should be fine. There are just a couple of more video settings on the 9000. The big difference between the two Panasonic units is build quality and audio. There will be differences of course in the power supplies used. Here's a comparison which pretty much sums it up.https://www.youtube.com/watch?v=77rwMAYe9M4
Thanks Phil...will watch that over the weekend.So either Panny model will play my movies from the NAS just like my old Oppo did - right? Also, will it provide all of the newer formats (including Dolby Atmos)?George
