Distance between AKSA 100 main board and transformer
0 Members and 1 Guest are viewing this topic. Read 1380 times.
rimljan99
I will soon start on the chasis for AKSA 100N and I got one question: Which is the minimum lenght between shielded toroid transformer and AKSA main board?
In my case is 40 mm between toroid and 7.5 A fuse on the main board. Is it enough, or should I change my chassis plan?
AKSA
« Reply #1 on: 28 Mar 2005, 09:26 pm »
Hi Rimljan99,
40mm is fine.  As long as your earthing is correct, there will be no hum at all.
Hugh
ginger
As Hugh Says
« Reply #2 on: 4 Apr 2005, 01:20 am »
For queries like this you can learn a lot by having a look at what others have done.
Checkout,
http://www.printedelectronics.com/discussion/discussion_gallery.html
See my 100W (Ian Miller - about the 8th one from the top). I had about 25mm separtion on this amp. That amp since sold to a happy AKSAphile and replaced with a 55N+.
A few amps in the gallery on that web page and lots more in the forum gallery (at the top of page 1 of the forum) with less than 40mm separating transformer and main board.
CAUTION: If using EI cored transformers rather than toroids then I would leave 40mm minimum separation.
Ginger.
