0 Members and 1 Guest are viewing this topic. Read 8505 times.
Agreed, if you drop a new piece of gear in your system and less of your music is listenable, you've gone in the wrong direction.
Not if the rest of the music took a big step up.
I have some underground Scandinavian Metal, that really sounds amazing on my new equipment.
I think the playback gear has simply gotten better and you realize just how bad some of the recordings are.I had an early Stones CD and CD-R of the same thing on yesterday and it was just dreadful.
Many years ago Grace Slick did an interview and she said they were concerned with a how a song would sound on a car radio when it was playing.Put it on a modern stereo system and well, it sounds like it belongs on a car radio!
I think most music(rock genre) is done to satisfy the many people who listen through their itty-bitty speaker on their smart phone,so no bass or lower midrange needed.If rock is your genre of choice,then buying CD's is kind of a gamble as far as quality of music.If I could refund all the money I spent on lousy sounding(but good music and playing),I would be a rich man! H50
If you haven't tried Qobuz yet, you should. No MP3's. No compression at all. 100% full resolution streaming. And not only that, a TON of stuff is also if full hi-rez (usually 24/96). And you get access to basically all major recordings by most major artists of all time (and the catalog is constantly growing). All for $13 a month. So that means you never, ever have to spend money on a bad recording. Want to check out a recording? Just do a quick search on Qobuz and it's usually there. Listen as much as you want. If the quality sucks, only thing you've lost is a bit of time. With services like Qobuz, you not only get access to all the great artists of the past, but also to all the great music that's being made now. For cheap. Seriously, it's the very best time in all history to be a music lover. The amount of quality music (and quality recordings) we have access to now has never ever ever been possible in the past. Re: recordings not having sufficient bass or lower mids, I disagree. I'm running recordings through my very large, very much full range speakers and I detect no lack of bass or lower mids. In fact, with some artists the bass in pretty insane. Like, I can literally feel my chair vibrating from the amount of bass produced.
I have Spotify and Amazon HD now,but only on my upstairs computer headphone rig via usb to Benchmark DAC1 USB...unfortunately I don't have usb access or a wireless streamer to listen to any streaming service(s)in my main listening room...maybe I should look into one(wireless streamer)).Thanks,H50
Spotify is absolutely compressed, all of it. It's never going to sound good on a high end system. Amazon HD is certainly better. But the real leap in quality comes with Qobuz and/or Tidal, and integrated in to Roon. Wireless is not a bad way to go but if. you can run ethernet cable, that's better sounding (and more stable). For endpoints, I really like the ones from Auralic. For less $$, the ones from Sonos have a good reputation, although I've not personally heard them. No need to live with crappy digital sound when getting really good sound is relatively easy.
Bluesound Node is probably the best option between sound quality and ease of use/setup. It doesn't do Roon, but it will let you stream your Amazon HD service in true lossless format.
Would a cheapy tablet work as a controller?Thanks,Huck
