Anyone who can repair a Dodd tube buffer?
0 Members and 1 Guest are viewing this topic. Read 810 times.
bfs21
« on: 11 Dec 2021, 05:30 pm »
I have a battery-powered Dodd buffer with passive gain.
It's a phenomenal piece (of course). But unfortunately there's a low level of persistent static. It gets more pronounced whenever you adjust the volume pot, so I'm thinking that's the problem area.
Does anyone know people who work on these? Reached out to one lead and never heard back.
I.Greyhound Fan
Re: Anyone who can repair a Dodd tube buffer?
« Reply #1 on: 11 Dec 2021, 06:50 pm »
Spray some deoxit in the pot.
S Clark
« Reply #2 on: 11 Dec 2021, 07:10 pm »
Yep. Try to get some contact cleaner into that Alps pot.
I'm sure you know that those pots were noisy when motorized, but were quiet when stationary.
Another thing that I just learned earlier this year is that the multi wire connectors can cause noise in those units. Mine got worse and worse until I changed out the pot... only to find that wasn't the issue.  I was about to send it off for repair when I discovered the problem was in the internal connectors.   Spray and clean those, along with your tube sockets.
richidoo
« Reply #3 on: 12 Dec 2021, 01:01 am »
Deoxit is great but use only the plain deoxit on potentiometers, never use deoxit gold on pots. Gold formula is for gold contacts and it leaves a residue behind which fouls plastic element pots.
CRC contact cleaner and electronics cleaner (without "protectant")  are also good.
bfs21
« Reply #4 on: 12 Dec 2021, 02:45 pm »
Duh -- just realized I posted in the wrong board. Thanks for the advice to those who replied!
Moderator, please remove. Sorry about that.
