FS: GR Research X-SLS cabinets
0 Members and 1 Guest are viewing this topic. Read 1033 times.
mflaming
« on: 9 Dec 2021, 12:41 am »
Built to spec dimensions with two mods. Edges are square to accept grill. Height is increased by 1.5", but internal volume is to spec.
Fully lined in NORES. Veneer is rift sawn white oak. Magnetic grill guards included. Port hole is milled in to spec location. No holes have been cut for binding post or connectors. Price is pretty close to material cost. Probably a hundred hours of labor in these at no charge.
$500
mflaming
Re: FS: GR Research X-SLS cabinets
« Reply #1 on: 9 Dec 2021, 12:42 am »
sorry I have no idea how to rotate an image on this forum
mflaming
« Reply #2 on: 9 Dec 2021, 02:03 am »
I need to clarify this listing. These are not GR Research branded cabinets. GR sells professionally built CNC cut cabinets using pro-grade materials and precise techniques. These are DIY garage built using home center materials - also precision built, but not to be confused with other offerings from production cabinet shops.
Phil A
« Reply #3 on: 9 Dec 2021, 01:56 pm »
Location (as I assume you don't have shipping boxes)?
Phil A
« Reply #4 on: 9 Dec 2021, 01:58 pm »
OK - see from the center channel ad you are in the Dallas, TX area.  Beautiful work!
mflaming
« Reply #5 on: 9 Dec 2021, 02:18 pm »
Yes, DFW area, but I roam the I-35 corridor from Austin to OKC fairly often, so could arrange shipping.
These are so heavy, shipping would be a fortune.
fre11111
« Reply #6 on: 26 Apr 2022, 11:04 pm »
Hi is this still available?
