Eminence Acoustinator N2012 woofers...
0 Members and 1 Guest are viewing this topic. Read 1760 times.
Chops
« on: 1 Dec 2021, 11:54 pm »
I keep forgetting that I have these darn drivers... EIGHT of them in fact!
Danny (or anyone in the know), what kind of bass response can I expect from these in typical H-frames, most likely two towers of four drivers per side?
For amps, I would probably go with a pair of Dayton Audio SPA250DSP plate amps which would be more than enough to power these woofers.
I figure I have these drivers, I might as well use them, especially now since I have the proper space for them. After using only a single one on each channel a while back, I know they are capable of pretty decent volume levels and bass output (on small flat baffles and one side wing), surprisingly so. I can only imagine eight of them in H-frames would be tremendously better.
Many thank in advance.
Chops
Re: Eminence Acoustinator N2012 woofers...
« Reply #1 on: 4 Dec 2021, 06:43 pm »
Wow... Okay...
NoahH
« Reply #2 on: 4 Dec 2021, 07:25 pm »
I suspect no one else has touched those exact woofers and this the silence. Perhaps you might look at the response curves for the woofers from GR in H frames and outside and assume a similar change?
Hobbsmeerkat
« Reply #3 on: 4 Dec 2021, 08:00 pm »
Funny you mentioned these woofers..
We're brainstorming an idea for a retro style speaker using them with some coaxial driver's we have on hand.
Not sure about their performance in open air tho. As they're really intended for a 1-1.75 cuft sealed cabinet, and likely dont habe the power to really achieve whats necessary to hit particularly deep as a subwoofer.
Danny would have to answer that.
« Reply #4 on: 5 Dec 2021, 02:43 am »
Weren't they originally used as the bass section in the V2. It wasn't an H frame but it was an open baffle.
S Clark
« Reply #5 on: 5 Dec 2021, 04:12 am »
I'm quite sure you're right.  Tyson had a pair IIRC.
Chops
« Reply #6 on: 5 Dec 2021, 12:53 pm »
Exactly. Heck, a purchased the darn things from Danny years ago BECAUSE he used them in the V2's.
Danny Richie
« Reply #7 on: 5 Dec 2021, 03:44 pm »
I have quite a few of those still in stock. I'll run some numbers on them and see what I can come up with.
They did work well in an open baffle too.
Chops
« Reply #8 on: 5 Dec 2021, 04:39 pm »
Thank you Danny. I would really appreciate that.
Another concern would be having 4' tall bass towers along side or behind the X-Statik's. I wouldn't want those towers effecting the overall sound staging and imaging of the X-Statik's. What's a good distance to have typical H-frames from the front wall?
Danny Richie
« Reply #9 on: 11 Dec 2021, 02:33 pm »
They need to be three feet or more out into the room.
And you can lay them on their sides in the middle of the sound stage.
