Sold: Exogal System: Ion amp and Comet Plus DAC
0 Members and 1 Guest are viewing this topic. Read 585 times.
RichardS
« on: 30 Nov 2021, 05:14 pm »
For Sale: Complete Exogal System, Ion amp and Comet Plus DAC.
Includes Hyperdrive upgrade, Clarity cable power cable upgrade and external power supplies for both units, remote.
List $7900
Sell $2599
Accepting personal check (after it clears) or Paypal (buyer pays fee)
Reason for sale: was looking for a small lightweight High-WAF system, but in the end decided to keep my Hegel H30 amp w/ Audionet DNP preamp/DAC.
125 watts per channel (into 8 ohms) 10 amps -- easily drove my Raidho D2 speakers
Ion: second owner, has Hyperdrive upgrade, 9/10. Comes with everything, sounds fantastic. I'll include an upgrade HDMI cable that I really liked, to connect the two units.
Comet Plus: second owner, 8/10. The Comet is the "plus" model, meaning it has the upgrade Exogal power supply. A couple small nicks on rear of power supply (see pic).
Reviews links:
https://www.dagogo.com/audio-blast-exogal-ion-powerdac-hyperdrive-upgrade/
http://www.tonepublications.com/review/exogals-comet-plus-dac/
http://www.theabsolutesound.com/articles/exogal-comet-digital-to-analog-converter
No kids, no pets, no smoking. Note my Audiogon feedback: richards, +600 feedback, 100% positive
In addition to the original IR remote, you can order from Exogal their upgraded Pulsar IR receiver and IR remote. The Pulsar converts IR signal to Bluetooth and transmits it to the Bluetooth interface of the Comet.
The Exogal Ion is a high performance PowerDAC that is specifically designed to be an amplifier and processing extension to the Comet. The Ion connects to the Comet via the EXONET Interface and provides 125 watts per channel (into 8 ohms).
The Ion integrates fully with the Comet and there are no complicated remotes or apps required - the Comet handles it all for you! Simply connect the Comet and the Ion together with one cable and you're done!
From Exogal:
HyperDrive
The Ion PowerDAC now incorporates some internal changes, yielding significant performance improvements. Existing Ions can be upgraded - see below.
Greater than 10% improvement in PowerDAC output power regulation, giving:
Approximately 10% more effective power
More robust bass at lower volumes
More articulate highs at louder volumes
Higher roll off frequency giving greater range
Flatter, more realistic frequency response all across the Ion's frequency and volume range
Also provides:
More reliable performance across wider mains voltage ranges
Faster, more accurate predictive speaker protection
Increased tolerance and protection from anomalous behavior
The Exogal Comet is a high performance digital to analog audio converter (DAC) playing up to 32/384k and DSD. Just connect your computer, or other digital/analog source, and experience exceptional audiophile quality sound. The Comet DAC does everything you would expect a high-end DAC to do, including balanced and unbalanced analog outputs, digital volume control and asynchronous USB input - all at a sensible price.
Features:
- Asynchronous USB, AES/EBU, SPDIF, Toslink, and line level Analog input
- Direct connection analog outputs with 32-bit Digital Volume Control
- Analog Outputs: one pair balanced (XLR), one pair unbalanced (RCA), one stereo Headphone
- Single ended and balanced analog outputs can be used simultaneously. Single ended outputs can be programmed as stereo, or center/subwoofer operation. Single ended outputs have a programmable offset level from balanced outputs
Includes:
Power supplies, Clarity cable, HDMI cable, original packaging, IR remote and wireless antenna.
« Last Edit: 4 Jan 2022, 07:01 am by RichardS »
