Triode Lab / Finale Audio AuPre Grande Line stage Tube Pre-amp SOLD
0 Members and 1 Guest are viewing this topic. Read 725 times.
joessportster
  • Set & Single Driver Bliss
SOLD Just simply a superb sounding pre-amp and looks stunning as well in Porsche Burgundy Metallic. Uses a pair of 12au7 for output an EZ 80/81 rectifier and an ECL805/85. Pre-amp also sports the SUPERB James output transformer. I have used this pre with about any amp out there SS and Tube, Push Pull and SET. It is DEAD (Im Talking GRAVE) QUIET. It is perfect in a system that needs no or minimal gain. If you can use a PASSIVE you can use this pre and gain DRIVE
Only selling because I am thinning thee heard (Its getting carried away) New the pre was 6K from my experience it sounds easily like it belongs in that lofty price range
This is Line Stage only (NO PHONO) this has factory installed parallel outputs so great for Bi-Amping or running a sub etc...
You ABSOLUTELY will not get a better sounding, quieter or better looking  Pre-amp in this price range. Will be securely packed with form fitting foam inserts and double boxed. Local pickup / audition welcomed at 28379 (Laurel Hill NC)
I will not be bothered if this does not sell, I simply love the look and sound. Finale / Triode Lab makes some superlative gear IMHO. Photos are the actual pre-amp offered, and are representative of the easy 8 out of 10 condition
My Price is 1499.00 OBRO (Or Best "REASONABLE" Offer) May Trade depends what you are offering
Manufacturer web site: http://www.triodelab.com/au-pre
Manual:  SOLD
« Last Edit: 24 Nov 2021, 06:32 pm by joessportster »
Meicheng
I'm just curious, what is the second set of RCAs about the outputs?
Meicheng
Never mind, I see you say it has dual outputs.  Should have read more closely....
