For Sale: Source Components
[SOLD]iFi iUSB 3.0 - $215
0 Members and 1 Guest are viewing this topic. Read 914 times.
Without music, life would be a mistake.
16 Nov 2021, 08:05 pm »
Open to offers on all of these.
SOLD
iFi iUSB 3.0
If you use USB with a power leg (ie, most USB DACs), the iUSB 3.0 does a great job giving you much cleaner sound vs. plugging straight into a computer. And if you have a dual headed USB cable, it’s even better. This one has some wear on it, especially around the corners. I also cannot find the original box fo it but I will pack it well in my own packing material. You also need to provide your own 5v power supply - recommend a good linear PS to get max performance from it. Asking $215.
SOLD -
iFi Zen DAC
Great sounding inexpensive DAC. Has an analog output stage designed by John Curl. Yes, THE John Curl. Another unit that’s near mint because I bought an iFi iDSD Pro almost immediately after buying the Zen DAC. Asking $80
Last Edit: 23 Dec 2021, 09:55 pm by Tyson
Re: iFi Source Components - USB 3, iOne Nano Streamer
19 Nov 2021, 04:42 pm »
Zen DAC is sold.
Reply #2 on:
14 Dec 2021, 09:44 pm »
iOne has a problem with one of the switches so I'm removing it from the ad.
Lappy27
Re: iFi iUSB 3.0 - $215
Reply #3 on:
17 Dec 2021, 04:44 am »
Hi Tyson,
Is the Micro iUSB still available?
Regards.
