VDA-1 and resistor sonics
0 Members and 1 Guest are viewing this topic. Read 1772 times.
tvr2500m
« on: 25 Mar 2005, 06:59 pm »
Dusty:
I'm loving the VAC-1/VDA-1 combo.
Quick question about resistor sonics, and I know the sound of different bits like this are are open to much discussion...  You seem to use Dale resistors in places I'm assuming are critical circuit areas.  Could I get your take on resistor sonics, particularly in the VAC-1?
- SJ
CIAudio
« Reply #1 on: 25 Mar 2005, 07:25 pm »
There are no resistors in a VAC-1, so I assume you meant VDA-1?
I chose the Dale/Vishay's because of their low noise and sound for the money. Various resistor types and brands do sound different in key areas.
I like good metal films for most applications. Carbon comp types can also sound good, but usually aren't available in 1% tolerance, and their value tends to drift over time.
