CI AUDIO Discontinuation All US Dealers ?
0 Members and 1 Guest are viewing this topic. Read 4660 times.
crossroadazn
« on: 25 Mar 2005, 02:52 pm »
Saw this add from Audiogon. Big discounts. :o
CIAudio
« Reply #1 on: 25 Mar 2005, 05:19 pm »
To keep our retail prices low, we have decided to eliminate our dealer base. This allows us to continue to offer the great value CIAudio products are known for.
In the US, our products may be purchased Factory Direct or through our catalog distributor (Music Direct).
There are still a few former dealers with discounts on their remaining inventory. These inventories are very limited and are dwindling fast.
If they have something you want, now's your chance to get a rediculous bargain.
Grover
« Reply #2 on: 25 Mar 2005, 05:52 pm »
Dusty -
I know you offer a 30-Day/No risk offer when people order Factory Direct.  Does that same offer apply if ordered from your catalog supplier, Music Direct?
Rob
CIAudio
« Reply #3 on: 25 Mar 2005, 07:29 pm »
I believe so, but you'd have to check with them to be sure.
dhiebert
    • http://darrenhiebert.com
« Reply #4 on: 19 Aug 2005, 03:24 am »
Quote from: CIAudio
Do you know of specific dealers which are discounting them?
CIAudio
« Reply #5 on: 19 Aug 2005, 03:45 am »
That post was almost 6 months ago...I doubt any old dealers still have inventory and were mostly odd products (VAC-3 etc.) which have since been discontinued.
Our current products are available through Music Direct in Chicago or factory direct from Channel Islands Audio.
http://www.amusicdirect.com
http://www.ciaudio.com
guest1632
  • Guest
imput caps for both amps
« Reply #6 on: 19 Aug 2005, 11:20 am »
Quote from: CIAudio
Hi Dusty, Well, I'm aware that you use some form of the UCD module. good enough. two questions: What op amps are you using on the imput side, and are you using thetypical DC protection with the two caps?
CIAudio
« Reply #7 on: 19 Aug 2005, 02:06 pm »
What op amps are you using on the imput side, and are you using the typical DC protection with the two caps?
Sorry but I won't go into details about our version of the modules. I can tell you that it is much more than a simple opamp upgrade. We make several changes in both thru hole and surface mount circuitry.
unityaudio.ca
« Reply #8 on: 17 Jan 2006, 06:29 pm »
I happy to see that dealers wil remain in the Canadian market.  :D
