USB switch for high res audio?
0 Members and 1 Guest are viewing this topic. Read 1894 times.
mike_p
  • You Never Blow Your Trip Forever
« on: 28 Oct 2021, 10:23 pm »
Has anyone tried this (2 dacs to a USB switch, and out to whatever depending on the source)? If so, what was the result, sonically?
mike_p
Re: USB switch for high res audio?
« Reply #1 on: 28 Oct 2021, 10:44 pm »
Or am I looking for a UBS hub? Maybe a powered hub?
mike_p
« Reply #2 on: 29 Oct 2021, 02:54 am »
I just picked up 2 DACs: a Denafrips Ares II and a Topping D90 MQA version. The Ares won’t decode Tidal MQA streams. I prefer the presentation of the Ares (more ‘meat on the bones’j but want to switch to the Topping for MQA decoding. I’m going to try a powered USB hub between the Roon Nucleus and the 2 dacs and see what happens . . .
mike_p
« Reply #4 on: 29 Oct 2021, 06:02 pm »
Are you suggesting something like 2 microrendu, 1 for each DAC?
Vincent Kars
  • The Well Tempered Computer
« Reply #5 on: 1 Nov 2021, 01:05 pm »
Wonder why because most of the time your PC contains a couple of (internal) hubs.
No need to add an external one.
In fact you can check the devices connected to each internal hub: https://www.thewelltemperedcomputer.com/SW/Windows/Win7/USBDAC.htm
mike_p
« Reply #6 on: 1 Nov 2021, 02:36 pm »
My first mistake was not accurately stating the problem. I have a Roon nucleus and two DACs, which I want to be able to select depending upon the streaming source I’m using. I forgot that the nucleus has two USB outs, and I can select the DAC that I want from the preamp. What I can’t do at this point is to find my stored high-resolution files on a USB drive attached to my Mac mini. When I go to the storage selections on Roon it allows me to add a network share but does not allow me to browse to find the USB hard drive attached to the mini. Does anyone know how to ‘see’ the network from the Roon software on my iPad? Sorry this was so convoluted.
Vincent Kars
« Reply #7 on: 2 Nov 2021, 11:36 am »
lokie
« Reply #8 on: 2 Nov 2021, 02:18 pm »
My guess is it's going to be both difficult and not worth it... as in too much sound degradation.
