Looking for new tubes on my Jolida SJ 502A...need advice
0 Members and 1 Guest are viewing this topic. Read 1313 times.
maxwalrath
I'm looking to replace all the tubes on my Jolida and I don't know where to start. My system is as follows:
Heart CD 6000 w/siemens 7308 tubes
JoLida SJ 502A w/stock pre tubes, ruby 6550 A-R power tubes
Meadowlark Kestral Hotrods
H.A.L. Tenderfeet
Signal Cable
The Kestrals replaced Dynaudio Audience 50's, and while the Kestrals sound better in nearly every other area, I miss the bass punch of the Dyn's. I don't know what tubes excel in what areas, or where to buy tubes, and I could use some guidance. If any of you out there have done some tube rolling with the Jolida or a similar amp I'd appreciate your input. I don't listen to much acoustic, most of my listening is classic rock at fairly high volumes.
Max
