FS - Phil Marchand WM8 Bassis - Subwoofer Equalizer $400
0 Members and 1 Guest are viewing this topic. Read 740 times.
Sonny
WM8 "BASSIS" Bass Equalizer
FYI, it does have a cover! :P
Subwoofer Equalizer
Adaptable to all acoustic-suspension speakers.
Adjustable bass boost and damping.
Two versions: 24dB boost max and 46 dB boost max.
Balanced inputs/outputs available.
20 Hz subsonic filter.
The BASSIS is a specialized parametric equalizer with two purposes: (1) to correct the irregular bass response of many acoustic-suspension loudspeakers; (2) to extend the bass response as much as two octaves lower. The damping (Q) of the new bass cutoff can be adjusted according to the listening room acoustics and the user's tastes. In consequence, any speaker can be corrected to obtain deep yet well controlled bass, providing music with a greater sense of impact and "openness".
BASS Response GraphCurve A is an example of the bass response of a typical "boomy" speaker, with bass falling off below 60 Hz. By adjusting the BASSIS, its own frequency response (curve B) may be made the inverse of the speakers curve, down to 15 Hz. The combination of the equalizer and speaker is shown in curve C, with a smooth response and a -3dB point at 15 Hz. Note that it is generally not possible to perform this sort of correction with a conventional graphic equalizer, due to the spacing of the frequency bands of the sliders.
The specialized parametric equalizer - BASSIS can also reduce the "boominess" of poorly-tuned vented loudspeakers; or the vent can be plugged for use with the full range of equalizer options.
The BASSIS employs a 4 amplifier bi-quadratic filter, with additional op-amps to allow independent adjustment of the various parameters, and to ensure system compatibility. The circuit contains high-speed op-amps, film capacitors and metal film resistors. Four rotary controls are provided for each channel, to match the cutoff frequency and damping of any acoustic-suspension speaker and to set the bass boost and net damping. A 20Hz high-pass filter (subsonic filter) can be switched in from the front panel to eliminate unwanted subsonics.
SPECIFICATIONS
Frequency response: 2Hz to 100 KHz, + 0.2 dB/ -3 dB
Harmonic distortion: less than 0.01% (at 1 KHz)
Signal to noise ratio: better than 110dB
Input impedance: 100K
Output load capability: 100 Ohm min
Output impedance: 10 Ohm typ
Maximum input voltage: 25 V peak-peak (8.8 V RMS)
Maximum output voltage: 25 V peak-peak (8.8 V RMS)
Power supply requirement:120 VAC, 60Hz, 10W
Dimensions: 17"W X 10"D X 3.5"H
Construction: All metal cabinet, black with white legend
FRONT PANEL CONTROLS and READOUTS
Bass boost range: 0-24 dB (0-46 dB)
Net Q range: .25 to 1.0
Speaker resonance range: 30 Hz to 130 Hz
Speaker Q range: -4dB to +6 dB at Xover frequ.
20 Hz Cut: on/off
Bypass: on/off
Power switch: on/off
REAR PANEL CONNECTORS
Input, output: RCA phono (2 each) (XLR balanced available)
Line power fower fuse: 1 Amp
Power: IEC connector for linecord
ORDERING INFORMATION
Several variations of the basic model are available. For balanced XLR inputs/outputs please consult factory.
WM8-AA Bassis equalizer 24 dB max boost, potentiometer for all controls
Sonny
Re: FS - Phil Marchand WM8 Bassis - Subwoofer Equalizer $400
« Reply #1 on: 29 Oct 2021, 04:35 pm »
Additional Pictures:
