reset the Dac 10
0 Members and 1 Guest are viewing this topic. Read 1448 times.
giordy60
reset the Dac 10
« on: 25 Oct 2021, 09:04 am »
hi Jason
is there a way to reset the dac10?
I encountered a problem:
on usb every now and then the song (from hdd) stops for a second and then starts playing again.
annoying glich also occur during playback, not always ... but there are.
i tried to change player and it does the same thing ....
I tried to change pc and it does the same thing ....
the strange thing is that from streaming (same player .. daphile always on usb) it doesn't.
i tried another dac with the same configuration (pc daphile usb) ... and everything works fine.
thank you.
rustydoglim
    • www.nuprimeaudio.com
Re: reset the Dac 10
« Reply #1 on: 27 Oct 2021, 07:23 pm »
It could be the file, check if it is the same file.
