Bryston bdp3 error 000 Mains Voltage Low
0 Members and 1 Guest are viewing this topic. Read 717 times.
Rush2112
« on: 24 Oct 2021, 06:48 pm »
Turned on the bda3 dac and bdp3 digital player to listen to some music . Bryston bdp3 showing error 000 Mains Voltage Low . I have unplugged the ac cords of both the dac and digital player for appr 1 min . Error 000 still showing up on digital player . Dac is working fine and goes to lock when i play the cd player through the dac . Is this something i can resolve on my own or will it have to go in for service ? Not showing error code 03 or 04 or 09 but 000 which seems odd . Any suggestions or help would be appreciated . Thanks
Rush2112
Re: Bryston bdp3 error 000 Mains Voltage Low
« Reply #1 on: 26 Oct 2021, 06:50 pm »
Heads up . Resolved my own issue . Removed top cover from bdp3 . There are 2 fuses marked fuse1 and fuse2 . Used multimeter on continuity test and fuse1 was blown . Replaced fuse1 and the bdp3 is good to go now so if you are getting error 000 Mains Voltage Low check the fuse1 and fuse2 .
