HIFI Flux vs Cardas Audio Frequency Sweep Record Mk II as a Stylus Cleaner
0 Members and 1 Guest are viewing this topic. Read 877 times.
undertowogt1
HIFI Flux vs Cardas Audio Frequency Sweep and Burn In Record Mk II.
I am seriously thinking about buying a FLUX HIFI Stylus Cleaner and have went down a stylus cleaning rabbit hole. Turns out you can use frequency sweeps off of test records as well to ultra sonically clean. Does anyone have experience with either the FLUX HIFI or a test record ( Cardas Audio Freq Sweep and burn in) . I have read pretty good reviews about the FLUX HIFI unit overall.  Thoughts are appreciated
« Last Edit: 23 Oct 2021, 07:27 pm by undertowogt1 »
toocool4
I don’t know about the Cardas but I do use the HiFi Flux.
I do use 2 different things to clean my stylus, I use both the HiFi Flux and DS Audio ST-50.
I use the ST-50 after both sides of the LP and I use the HiFi Flux at the end of every listening session.
The HiFi Flux is very good and does a very good job.
I would recommend both the HiFi Flux and the DS Audio ST-50. Not necessary to have both, either one will do the job well, I just happen to have both.
