Grills for the X Static speaker
0 Members and 1 Guest are viewing this topic. Read 927 times.
Mallard1
« on: 21 Oct 2021, 05:33 pm »
Are there any plans available to make speaker covers for the X Static DIY kits?
Any help will be greatly appreciated.
Danny Richie
Re: Grills for the X Static speaker
« Reply #1 on: 31 Oct 2021, 11:51 am »
We have not created such plans yet. Most run them without grills as the grill frames tend to disrupt the response.
dryan01uk
« Reply #2 on: 2 Nov 2021, 09:05 pm »
Hi,
I'm at that stage with my build - got to keep the kids / adults fingers out of the drivers.  There are lots of examples of grills for X-Statik and other designs in this circle.  Here's what I did... and apologies for the rough finish - nothing is rubbed down or finished yet (and I'm a noob woodworker!):
I used 6mm plywood for the grill frame which seems to work well.
Grills fitted to X-statik and sitting in front of X-Voce.  the drawings allow for centre positioning of the driver holes - I made the grill driver holes 7" diameter for good clearance.  I've yet to round-over the internal angles.
Detail of the 8mm dia. / 3mm thick magnets buried in the various speaker baffles (I used eight per baffle and eight per grill) - make sure to get the polarities right!! I also superglued (CA glue) them into place to stop them dropping out:
Grill stand off and magnets:
more images :
I intend to paint these in black duratex, going for a smooth-ish coating, then fit (probably glue), the speaker fabric.  The small magnets are surprising strong and take the weight of the plywood comfortably.
Hope this info helps?
David
Mallard1
« Reply #3 on: 3 Nov 2021, 04:01 am »
Those look great!    I’m looking to make a set of covers to keep little fingers out of the dust caps  also
I listen with drivers uncovered but like the protection when I’m not looking or around.    Thank you for the help.   Greatly appreciated
