Front Wall Foam Diffuser Recommendations?
0 Members and 1 Guest are viewing this topic. Read 1547 times.
zenfishbike
« on: 17 Oct 2021, 04:16 pm »
Planning for my future NX-Oticas. I believe diffusers are recommended on the wall behind the speakers correct? I also have a TV centered on that wall. Currently I place a heavy blanket over the TV when 2-channel listening. I'd like to step up that treatment and am thinking about those foam diffusers that would be light enough to hang in front of it and be easily moved in and out as desired. I understand these need to be painted to be effective which provides a decorative advantage. If this idea has merit I'd probably use the same ones mounted to the walls behind the speakers as well for continuity. So you can see what I'm trying to accomplish. What have you done here and what other considerations should I be aware of? And which manufactures do you recommend? Thanks!
radarnyc
Re: Front Wall Foam Diffuser Recommendations?
« Reply #1 on: 17 Oct 2021, 06:22 pm »
I don’t have these but others seem to like Mr T from PI Audio. https://piaudiogroup.com/
nature boy
« Reply #2 on: 17 Oct 2021, 06:40 pm »
I use the PI Audio diffusers. They work extremely well in my listening room, easy to pin to drywall, and don't cost an arm and a leg👍.
NB
mlundy57
« Reply #3 on: 17 Oct 2021, 07:29 pm »
I also use the PI Audio Mr T diffusers
timind
  • permanent vacation
« Reply #4 on: 17 Oct 2021, 08:00 pm »
Another happy PI Audio customer here. I use the Command Picture Hanging Strips, the ones with velcro.
S Clark
« Reply #5 on: 17 Oct 2021, 08:04 pm »
Another Pi Audio user.  :thumb:
RonP
« Reply #6 on: 17 Oct 2021, 08:53 pm »
+1 PI Audio Mr T
Hint: Have Greg paint them black for you.
Chewbacca
« Reply #7 on: 18 Oct 2021, 01:57 pm »
Also a very happy Pi Audio diffusion user. Great performance, great price, great look! :thumb:
zenfishbike
« Reply #8 on: 18 Oct 2021, 02:35 pm »
Well if there ever was such a thing as consensus in this sport this could be it. Thanks guys.
e_biz80
« Reply #9 on: 18 Oct 2021, 09:37 pm »
Just got Mr. T panels from Greg. Holy crap do they ever make a difference. Sound stage just got even deeper and more defined. My Open baffle speakers definitely needed them on the front wall.
PDR
  • May the best man win
« Reply #10 on: 18 Oct 2021, 10:33 pm »
I built my own using QRDude.
Foam cut with hot wire and then a thin set applied with
a small kinife on the foam, then paint to match.
It really was easier than it looks.
It was fun to design and build as well......but, I'm a DIY nut.
I must of had these for 8 or 9 years now.
https://www.subwoofer-builder.com/qrdude.htm
This was an earlier attempt.....just a poly diffusor made simple with a 1/8" of
your choice of panel....
zenfishbike
« Reply #11 on: 19 Oct 2021, 01:26 am »
I might add DIY absorbers to my "to do" list but diffusers not likely! That amp stand is spectacular, if you built that would you mind sharing the details please?
