0 Members and 1 Guest are viewing this topic. Read 3399 times.
Mag in my experience when buds want to pop out they are too large.I have also found that for some iems, I use different sized tips in each ear (found especially true with foam tips for some reason).
Hi,Glad you like the Yamaha TW-E3. I wasn't aware that Yamaha made wireless IEM's so this is news. I've tried a couple of wireless earbuds and so far I've had the following IEM's:1. EarFun Free Pro True Wireless Earphones - these were quite good for a budget iem but the bass was a bit shy.2. Noble Falcon True Wireless In-Ear Monitor - these were quite bit more money and only stopped using them because I lost one of the earphones.3. Final Audio ZE3000 Wireless Earbuds - these iem's are the best so far being a little cheaper than the noble falcons. They are the closest so far to using over ear headphones. - recommended if you want to pay a little more.4. Sennheiser CX Plus True Wireless Earphones - these were on special and I'm waiting for them to compare with the final audio ism's. They utilise active noise cancelling so they should be good for the office.Cheers Rod
