Bryston 10B STD Crossover
0 Members and 1 Guest are viewing this topic. Read 1004 times.
TJB
« on: 16 Oct 2021, 01:32 am »
Anyone,
What does a crossover do?  And would my Thiel CS2.3 speakers benefit from using this one?
Jon L
Re: Bryston 10B STD Crossover
« Reply #1 on: 16 Oct 2021, 04:22 am »
Bryston 10B are Active crossovers.  In order to use it with your Thiels, you would have to disconnect the Passive crossover inside and provide 3 separate channels of amplification per each speaker, one per driver.  You actually would need TWO Bryston 10B active crossovers for three-way speakers like yours.
Some basic info:
https://www.clearvibrations.net/passive-vs-active-crossover-networks/
TJB
« Reply #2 on: 21 Oct 2021, 11:17 pm »
In this case, I will not be getting one.  Perhaps if I had some cheap speakers, I would have considered it.
hawkeye99
« Reply #3 on: 23 Oct 2021, 09:45 am »
I realize you're are inquiring about the STD but there is also a 10B-SUB for integrating subwoofers. Just a fyi in case you were unaware.
