WTB a mid to higher end dac....
0 Members and 1 Guest are viewing this topic. Read 821 times.
2bigears
« on: 14 Oct 2021, 09:56 pm »
 :D hi, if your in the hunt for a better dac,, and want to sell your newer very good dac,, drop a note please.
               It should be above and beyond my Tranquility dac from Eric and his upgrade and cable.
     Regards.  Pascal in Canada  :D
jmolsberg
Carlman
Re: WTB a mid to higher end dac....
« Reply #2 on: 15 Oct 2021, 03:57 pm »
Never heard the Border patrol but this guy is a gem:  https://www.audiocircle.com/index.php?topic=178566.new#new
They screwed some people in their funding campaign so they got a bad reputation as a business.
Their public relations loss is your equipment gain! (that's the way I look at it)
If they still had a good reputation, this DAC would be in the thousands.
alke1234
tamcongdinh
« Reply #4 on: 16 Oct 2021, 10:45 pm »
you show the price range you're looking for, should be better
Escott1377
« Reply #5 on: 23 Oct 2021, 04:42 pm »
Look at the current offering from Musical Paradise.  Search the forums and there are lots of discussions.
I run mine with Clarity silver caps and a pair of WE tubes for SE connections.
Buying the basic with ESS chips, very affordable.
You can upgrade your caps and tubes once you learn the sound of the DAC.
BTW - it is not pretty but sure does sound great.
Good luck and have fun!
Creed
« Reply #6 on: 29 Oct 2021, 02:48 pm »
Sent you a pm, I have a Mhdt Havana upgraded caps and Garage 1217 tube adapters, 6922 and 6sn7 if interested
