0 Members and 1 Guest are viewing this topic. Read 3869 times.
What is the overall height of these John?
When a speaker sounds too loud, it is most often because distortion levels become too high. If you take a small boom box and drive it too high, the distortion becomes objectionable and you have to turn it down. But a good full-range speaker will play at even higher volume levels without sounding too loud. The difference is distortion.
jd3 -The Purifi woofer's claim to fame is primarily their incredibly low distortion levels. That is why you sometimes find yourself listening at higher levels than you realize. When a speaker sounds too loud, it is most often because distortion levels become too high. If you take a small boom box and drive it too high, the distortion becomes objectionable and you have to turn it down. But a good full-range speaker will play at even higher volume levels without sounding too loud. The difference is distortion.With these woofers, the distortion levels are so low you don't get those normal distortion cues. At the same time, you get the illusion that there is more detail in the mids. I say "illusion" in that there are drivers on the market that are even more detailed (and we use some of them). But they also have higher distortion levels when driven harder. The Purifi drivers can appear to have more detail due to the fact that distortion is not masking the detail that is there.- Jim
Where can I see more or learn more about these new speakers? Sounds very interesting with the new Purifi drivers!
Is the degree of cone movement a major factor affecting distortion?
Jim,As far as distortion is concerned, how do these compare to the Accuton from the SS series? Also, can I assume that the impressive XMAX really helps in a 2 way design, where the woofer is performing mid-range and bass duties vs a true 3-way design. Nick
The Accuton cone is likely more detailed, but also higher in distortion when played loud.- Jim
