Questionable improvement, but free on Aksa
0 Members and 1 Guest are viewing this topic. Read 1228 times.
PT914
« on: 23 Mar 2005, 05:15 pm »
While changing caps at C1 on the Aksa amps, my sleeve caught the edge of the ceramic resistors that are under the amp board, where bias is checked.  This caused a ring that was almost like a musical instrument.  Guest this resonance was amplified by the heat sink.  Maybe when the heat sinks are screwed in, it might not ring so much.  Anyway  I hot glued the corners of the ceramic resistors and the RTX cap to the board so they wouldn't ring.  I think it made a difference in sound, but I can't be sure.  I have a tri-amp system and did this to the tweeter and midrange amps.  I only changed C1 on the tweeter amp and the improvement in the tweeter amp was so great it overpowered the slight improvement I think is there in the midrange.  Improvement to midrange is quite difficult listen for.  Anyway, maybe someone else could see if this is an improvement.
Philip
