0 Members and 1 Guest are viewing this topic. Read 2601 times.
First Nick,Would you consider adding a sound bar if you are happy with the video performance? I'm assuming that model has audio outputs that a sound bar would need. If you opted for a sound bar make to purchase it from a place with a good return policy, just in case in doesn't work because your tv's audio is completely shot. If you made up you mind to buy new there are many options and I recommend you look up reviews on TVs that meet your desired options. Start with size (or price?), price, options (really have a list of must haves), and lastly the ratings of the establishment you are going to purchase if from. I am not going to get into the current technologies, OLED, QLED, etc., because if you read reviews they will probably explain it better. I would also play good attention to the audio quality rating too. Lastly, check out out owner reviews for the models you are thinking about and use them also as a guide. The internet has made this research easier but the truth is looking at the picture in person should be the final step before purchase. So if possible check out the TV in the store or showroom. Good Luck!
I recall reading an article (don't recall where) several years ago that Costco electronics, i.e., TVs, cost less because the parts are cheaper. The model numbers are slightly different than models one would find at other electronic stores because the parts are not the same. So you may want to check the particular Costco model you are interested in against the model at at a Best Buy or other electronics store. If the numbers are the same, then all should be good. I like OLED TVs from Sony and LG. I would also concur with getting a soundbar with a subwoofer, as TVs become ever thinner, the sound quality tends to diminish. Good luck.
Have you seen these? I don't know if either applies in your case.https://www.youtube.com/watch?v=sUWAdjXvuFIhttps://www.youtube.com/watch?v=ViEmCcZQDc8Or search for Fix Samsung TV volumeI take it that you can't change the volume directly by using the buttons on the TV?Me I would look at the LG or Samsung at Costco. Under $400 in a 43".
Maybe I missed it but believe from your post speaking of the volume of the TV, does that mean you are using the built in speakers? If so, have you tried output from the 1/8 inch headphone jack? If audio is there, using a mini jack to RCA would open play back possibilities.
