Need advice for HT set up
0 Members and 1 Guest are viewing this topic. Read 871 times.
morganc
« on: 25 Sep 2021, 04:35 am »
I’ve got a new home and am setting up a small home theater room that measures 15x16 feet.
Currently I have two Dual Servo H Frame Subs not in use.   Though when I get my Spatial X3’s in the living room set up I may want the subs there but that’s a bit down the road.
Options include
1. GR Research OB 7’s. I’ve never heard them but they are available locally.
2. Build a top section from the GR Lineup.  What would be the best kit  for this room?   What kits are in stock or will be soon with the next shipment?
3. Buy a used top section or X Static  from someone reading this :)
4. Build an X Static kit.
Or I could just say,
5.  it’s just HT, buy some decent floor standers off EBay or US Audio…..
Open to y’all’s expert opinions    :popcorn:
Again I’ve never heard the OB 7’s but did own an X static ages ago.  How do they compare?
morganc
Re: Need advice for HT set up
« Reply #1 on: 25 Sep 2021, 05:21 pm »
Next Question....How would an X-Voce match with OB-7's?  How close the drivers and tweeter?  I am not looking for perfection here...passion is 2 Channel but love to hear great dialogue in movies, and enjoy music in movies as well.
« Reply #2 on: 25 Sep 2021, 05:38 pm »
Very good matching between the 2.  And the OB 7's are excellent speakers, if you can get them already built and also local?  That's a no brainer.
morganc
« Reply #3 on: 25 Sep 2021, 06:05 pm »
Yep, that is what I thought as well Tyson.  And from a stand up guy as well.
Much appreciation.
Morgan
Vince in TX
« Reply #4 on: 27 Sep 2021, 01:10 pm »
I went with the X-Statics, X-Voce, A/V-1RS surrounds and a pair of Servo Sub 4 kits for my home theater (in-ceiling are Bowers & Wilkins CCM684, and I have an SVS PB-2000 Pro at the back of the room, otherwise the entire theater is GR Research  :thumb:):
