0 Members and 1 Guest are viewing this topic. Read 4595 times.
What considerations do I need to make for the fact that the full-range (Lii F15) drivers I am pairing the tweeters with, are 8ohm and the tweeters are 4 ohm?Usually they use a small cap to match the 4 ohms impedance tweeter.https://www.erseaudio.com/First-Order-2-WayBy the factory freq chart the F15 perform nicely til 15kHz it makes sense add a supertweeter, in some cases it dont need a xover.
I wouldn't worry as much about the impedance difference. You can always use an L-pad (resistor in series and resistor in parallel with the speaker) to turn the tweeter down if it is too loud. I would be more concerned with phase issues since the Lii F15 is a full range speaker and then you will be adding a tweeter on top of it. Since both drivers will be producing the same high frequencies but the tweeter will have a crossover filter (I recommend using at least a 2nd order filter for the tweeter) some of the frequencies will be out of phase. For example, if you use a 2nd order filter at 6k then 6k on the tweeter will be 90 degrees out pf phase from the F15. This generally works well if the woofer is low passed with a 2nd order filter at 6K because then the drivers are 180 degrees out of phase and switching the polarity on one of them can fix it.What are you trying to achieve by adding the supertweeter? It seems to me that it will cause more problems than it solves. The F15 is smooth to 15k. A lot of people don't hear above 15k.
Thanks for the thoughtful response Danny. I have a Deqx DSP/DAC which I use mainly for crossover and time delay correction for the Lii full-range driver and the subs. I could also use it for a crossover to the tweeter at from 48 to 300 db/octave, either linear phase, LinkwitzRiley or Butterworth, if that's any help? I'm not worried about trial and error (time to indulge in experiments like this is one perk of retirement ) and I'm not going to slit my wrists if I can't make an improvement with the tweeters. As you and others have pointed out I might be introducing more problems than improvements, and if that's the case....I'll remove them and move on. And I won't complain that I wasn't warned
I'm thinking I'll get a stereo power amp to drive the tweeters, and remove the need for the passive components (apart from the 30uf turn on protection capacitor). The Deqx DSP will be the active crossover and will set gain, delay, EQ, phase, etc. Can you recommend a suitable amp that would drive the 4 ohm tweeters nicely?
Update time - I've tried the tweeter in several configurations - using the Deqx as active crossover and powering the tweeters with either the Tripath or Yamaha amp, at crossover frequencies of 2.5khz, 6khz, 10khz, and 12khz. I've tried with and without Deqx calibration, and with and without DSP correction. I've also tried using a resistor & capacitor crossover (@ 12400hz) - both via the Deqx, and directly through the tube amp without the Deqx. I've also tried using just the full-range driver on its own, both via the Deqx and directly through the amp.My preferred configuration so far is to just use the full-range drivers without the tweeters, via the Deqx, using the Deqx's calibration & correction, crossover, group delay, and DSP capabilities. The tweeters detract from the coherence of the image and soundstage, and of course I was hoping for the opposite. And I'm not detecting any lack of highs, harmonics, etc without the tweeters in play.I won't make a final decision until I hear back from my UK Deqx guru, who has my Deqx speaker measurement files to fine-tune. If he works some magic with the measurements that included the tweeters and comes up with a sound that I prefer to full-range only - well and good, I'll go with that. If not, I'll stick with the tweeterless OB's - which are sounding really good just with my inexpert Deqx corrections. And I'll have some tweeters and amps to sell
