Best Tube PreAmp under $800
0 Members and 1 Guest are viewing this topic. Read 4033 times.
Kruds
« on: 20 Sep 2021, 11:31 am »
What is the best tube preAmp you have used that cost under $800?
My two current favorites (that I have) are an (Cary/AES) AE-3 and a George Wright WLA-12A.
What else should I look at?  (Generally, I like 6SN7 variants)
Re: Best Tube PreAmp under $800
« Reply #1 on: 20 Sep 2021, 07:08 pm »
Hi Dave,
The Starting Block Circle is really for people to introduce themselves.
This question/thread is best posted in the Tube Amp Circle, so I wll move it there for you now.
Delta77
« Reply #2 on: 20 Sep 2021, 07:54 pm »
I haven’t had any experience with them yet , but I think you might want to look at maple tree audio..
https://www.mapletreeaudio.com/#Preamplifiers
He has his , “Line 2CRM line preamplifier with remote volume control and PS 2D power supply “  listed for $800..
Not sure if that price is current..?
Chris Adams
« Reply #3 on: 20 Sep 2021, 08:21 pm »
Schiit Freya and current model Freya+ are very good sounding and versatile pieces. I owned a Freya. The Freya+ is a bit more than you want to spend but both can be found used for less than $800.
« Reply #4 on: 20 Sep 2021, 08:28 pm »
Eastern Electric Mini-Max preamp over $1K a rich tubed sound to match a SS amp.
« Last Edit: 20 Sep 2021, 10:19 pm by FullRangeMan »
nc42acc
« Reply #5 on: 20 Sep 2021, 09:11 pm »
Used Schiit Freya
mick wolfe
« Reply #6 on: 21 Sep 2021, 04:06 pm »
I agree. The Schiit Freya +....this especially if you've got a plethora of NOS or ANOS 6SN7's in your stash. Just bump your budget to $1K and don't look back. (15 day audition/return option is a big plus if buying new) To clearly beat it with other options in new 6SN7 based pre-amps, you'd have to spend at least 2 or 3 times as much.
nc42acc
« Reply #7 on: 21 Sep 2021, 04:24 pm »
Original Freya more “tubey” sounding. I tried the plus and sent it back and kept my original version.
mick wolfe
« Reply #8 on: 21 Sep 2021, 04:39 pm »
Oops, didn't notice "original" Freya, but the Freya + will give one "tubey" when matched with many of the ANOS 6SN7's I've tried.
Kruds
« Reply #9 on: 22 Sep 2021, 02:18 pm »
Anyone have experience with the Schiit Lyr, either version II or III?
rotarius
« Reply #10 on: 22 Sep 2021, 09:32 pm »
I have owned the earlier version of the Mapletree.  Excellent pre, replaced with an Aes Ae3 DJH and I was not sure if that was really an upgrade.  I should have kept that one.  I am sure the new version sounds just as good.  That would be my pick.
