SOLD: Symposium Precision Couplers
0 Members and 1 Guest are viewing this topic. Read 714 times.
Cave
« on: 14 Sep 2021, 01:31 am »
I have 2) sets of these, new.
$100 for set of 4 new.
Buyer pays shipping from 97003, paypal please add 3% if not friends/family.
From Symposium:
https://www.symposiumusa.com/pcouplerstech.html
The Precision Coupler replaces our former Large Coupler to provide improved performance and convenience. Made of top-grade 7075 aircraft aluminum and precision machined to scintillating surface finishes, Precision Couplers are used to form an efficient mechanical connection to the components placed upon Symposium Platforms and Isis Rack levels, for effective damping of internal equipment resonances - an essential requirement for best results with vibration control devices. The high mechanical transmission efficiency of the aluminum alloy also provides an excellent transmission path for the evacuation of mechanical energy out of components and into a mechanical ground, where it can be absorbed and/or converted to heat energy.
All Symposium platforms work best with a good mechanical connection or pathway between the component's chassis and its top layer; soft materials, such as rubber or sorbothane, impede the transmission of mechanical energies. Think of the Precision Coupler as the mechanical equivalent of the theoretical "Straight Piece of Wire" in an electrical circuit: its sole purpose is to conduct mechanical energy without amplification, attenuation, or filtering. In this way, internal mechanical noise (vibration) can be conducted directly out of the component and into the Svelte Shelf, where these energies can be converted to harmless heat energy without added colorations. If your component already has built-in metal feet or has a flat bottom which will be placed directly upon the platform, or if you already have special footers for this purpose, then they are not necessary. Precision Couplers will not add any "harshness," will not exaggerate bass, or "spotlight" upper midrange. In other words, they are neutral. We recommend them if you don't have an alternate, suitable "footer" device, such as Symposium Rollerblocks, cones, or some other appropriate footer device.
Each Precision Coupler features nearly perfectly parallel top and bottom surfaces, and one side has a threaded 1/4-20 hole for attachment to similarly threaded foot posts or for screwing two Precision Couplers together to form one high coupler to clear very high feet. The Precision Coupler is 13/16" (0.8125" or 2.06cm) thick; two joined together form a double thickness unit that is 1 5/8" (1.625" or 4.12cm) high.
« Last Edit: 20 Jan 2022, 11:57 pm by Cave »
Cave
Re: Symposium Precision Couplers
« Reply #1 on: 29 Dec 2021, 10:02 pm »
bump 90 each set of 4 new
