*SOLD* Thoress Full Function Super tube preamp with 3 MC inputs - 100 ohm
0 Members and 1 Guest are viewing this topic. Read 1665 times.
grannyring
Sold …………Asking $2750 .  These sell for $9650 new.  Good luck and thanks for looking.
This is a hand crafted piece made in Germany. No circuit boards and all point to point, tag strip soldered design. The build quality is first rate and all but non-existent anymore.
It is a combo Linestage along with 3 phono inputs. The preamplifier offers two inputs for high-output sources (such as CD players or dacs), one input for low-level
line sources, and three phono inputs for MC phono cartridges. Each phono input is currently set up for 100 ohm. This can be changed by simply soldering another value resistor on the given input.
To maximize versatility, the preamp includes two (paralleled) main outputs and a monitor output.
The phono section within the “Super” (located in the right-hand side of the case) amplifies the MC signal actively (employing one PCC88 and two 12SN7GT tubes). The line stage uses one 12SN7GT tube per channel.
The preamp does invert phase. Please see the link to the Thoress site and manual.
This preamp did experience some internal shipping damage when the owner shipped it. The on/off switch was replaced with the same exact part and works as it should now. In addition, some tag strips were broken/cracked in several locations. No parts were damaged and the circuit was 100% in tact. All solder joints were in tact and original. Strong two part epoxy was used to repair the tag strip breaks and all is now secure and strong. See internal pics. She works as new.
I took this unit on a trade and repaired it. I have a digital front end and thus this piece is not needed. See my feedback under grannyring on Audiogon. I modify/upgrade gear and build cables.
I have the original box and packing. I prefer a pick up or meet in the middle situation to avoid shipping this beauty. I live in the Nashville, TN area. Exterior condition is very nice as the pictures show. Overall rating reduced due to tag strip repair.
I  accept PayPal,  Cash, wire transfer, and check once cleared.
Thanks for looking !
Bill
Here are some professional reviewer comments. You can find the full reviews with a quick google search……
" Once warmed up the most obvious attribute of the THÖRESS pre-amp is a beautiful harmonic structure and well laid out soundstage. This is like no other pre-amp I have heard and you are really drawn into the music. Once heard you will find it hard to live without the THÖRESS. "
" The phono stage is amazingly quiet for an all valve circuit, the system is so transparent with no distractions from noise. "
" It did not seem to matter what I was listening to, the THÖRESS was able to let you hear the music as intended. The MFA pre-amp seems rather flat and dull in comparison. "
" The THÖRESS let my favourite music and artists perform at their best, the vocals seemed much more natural and realistic than I have heard with other setups. You don't realise what is being added until it is suddenly not there, and you hear what the artist really intended. I will miss the THÖRESS pre-amp, it will be hard to return to my regular system.
( Mike Cox, TNT Audio - UK )
« Last Edit: 11 Sep 2021, 03:16 pm by grannyring »
morganc
A Plus seller and high integrity guy here with great ears!  If I needed a Pre I would check this one out.
Markwatkiss
Ictwoody
  • Art Director. Artist. Kansan.
Where are you located?
- Woody
grannyring
Nashville, TN area.
grannyring
« Last Edit: 4 Sep 2021, 06:34 pm by grannyring »
grannyring
Price reduced to $3000.  Yes, just $3000 for this hand crafted tube preamplifier selling new for just under $10,000.
grannyring
Price reduced to $2900.
joessportster
  • Set & Single Driver Bliss
PM Sent
grannyring
Price lowered to $2750
