Nuprime and Magnepan
0 Members and 1 Guest are viewing this topic. Read 5573 times.
I.Greyhound Fan
Re: Nuprime and Magnepan
« Reply #20 on: 27 Oct 2021, 08:28 pm »
There are plenty of high power SS amps that don't get that hot. The Parasound A21 comes to mind as I use to use it with my Maggies.  It just got warm.  Now my Pass amp gets very hot but it runs in class A for the first 15 or 20 watts.
nandan
« Reply #21 on: 27 Oct 2021, 09:43 pm »
apologies, double-posted.
nandan
« Reply #22 on: 27 Oct 2021, 09:43 pm »
Nandan,
Nice looking system.
I might ask if you are using Single Ended or Balanced  from the DAC-10 to the AMPS?
I have tried with both, and the top-end volume doesn't seem to change[1]. It's loud, just not as much I would like for Rock, although it's fine for Jazz, and middling for Classical. In any case, I mostly appreciate that my system doesn't have that so-loud-the-neighbors-knock character, but I would like the option to have people tell me "it's too loud, could you turn it down please!"
To answer your question, I was using Balanced because with Unbalanced I cannot use the volume controls on the DAC-10H
[1] Tested with Sibelius, Gorecki, GnR & Dulce Pontes
