0 Members and 1 Guest are viewing this topic. Read 3858 times.
thank you. I am looking at the block and the strip of tin foil is held in with blocks that are simply screwed down. The ribbon is 5 bucks,,,,,ha. Just waiting to hear back from ProAc. G2i or G2Si ,,,, ? Might be easy to replace the tin foil ,,,,, Thanks much for the links. You guys are the best.
I’ve made a replacement ribbon for my Gs2i out of aluminum foil. Not that hard, you use the Fiskars paper crimper. Basically you cut the foil the correct width and run it threw the crimper, you have to make sure you run it straight. My best tip is to use non magnetic tools when assembling it. And no I could not tell the difference between the tweeter I fixed and the original one. Good luck
