SOLD: MHDT Orchid NOS DAC - as New with WE396 Tube
0 Members and 1 Guest are viewing this topic. Read 466 times.
doggie
« on: 24 Aug 2021, 12:50 am »
SOLD>>>
Selling my MHDT Orchid DAC. Comes with stock NOS 2C51 tube and also a NOS Western Electric 396a.
This DAC was purchased new in April 2021 and has only a few hours on it. This is an excellent DAC. I am selling it to move to an solid state DAC with an AES/EBU output that I can leave on 24/7.
Selling for $945 plus shipping in lower 48 US. I will absorb PayPal.
Sells new for $1310 + tax and shipping from Linear Tube Audio with the WE tube.
Includes DAC WE tube, original box, original tube. No power cord
Specs:
ORCHID
Orchid DAC is capable of up to 24bits/192kHz digital signal inputs, driving the legendary TDA1541A R-2R digital to analog output.
The USB input section is asynchronous.
Total four independent digital inputs; BNC, USB, RCA and Toslink.
The four (4) digital inputs are independent to each other, only one among them will be active and is controlled by the physical switches located in front panel.
Tube buffered output, tube installed is GE5670 3 mica tube.
Tubes that can be used: 5670, 2C51, 396A, 6385, 6CC42, 6854, 6N3, 6854, CV2575, CV4013, CV5894, CV8247, CV2381
115/230V power supply selectable from internal PCB jump pins setting
Power cord not included.
SPECIFICATIONS
Digital Receiver CS8416
D/A converter: TDA1541A
I/V stage: discrete ideal transistors (OPA861 used as transistor), no feedback
Frequency response: 20 Hz to20kHz (± 2dB)
Output impedance: 32 ohms
Output level: 3 Vrms
All inputs support 16/24 bits/ 32 kHz up to 192 kHz
Dimensions: clear (W x D X H) 276 x 150 x 60 mm
Dimensions w/ socket: (W x D X H) 295 x 170 x 60 mm
Weight: 2kg
« Last Edit: 10 Sep 2021, 09:41 pm by doggie »
