Tube preamp
0 Members and 1 Guest are viewing this topic. Read 1079 times.
egeeks
Tube preamp
« on: 20 Aug 2021, 06:52 pm »
I'm trying to decide on a good quality tube preamp. I see the Schiit Freya + & others under $1K. I saw this Diginity PM-201 offered @ $500. I also see Vincent SA32. Suggestions please?
Re: Tube preamp
« Reply #1 on: 20 Aug 2021, 08:56 pm »
Welcome to AC  :thumb:
As all in audio the best tube equips are the simplest circuits and contructions, I dont like noval tubes but this Eastern Electric Minimax preamp always have great reviews>
http://www.glowinthedarkaudio.com/minimax.html
Aside that I remember the late Omo Tube preamp (Matisse emulator) was superb under 1 grand, the Omo layout was similar to the Minimax.
« Last Edit: 21 Aug 2021, 12:10 am by FullRangeMan »
nc42acc
Re: Tube preamp
« Reply #2 on: 20 Aug 2021, 09:26 pm »
Hard to beat the Freya + if you can live with the limited inputs. Really great sounding preamp.
Phil A
Re: Tube preamp
« Reply #3 on: 21 Aug 2021, 12:07 pm »
Welcome!
Escott1377
Re: Tube preamp
« Reply #4 on: 21 Aug 2021, 02:36 pm »
My current pre amp is the MP-701 MK2 Tube Preamp Pre Amplifier.  It can be had for under 1k.
Unlimited combinations available with tubes and capacitors.
I also posted my initial thoughts when I received the unit in the Tube circle.
Good luck!
Re: Tube preamp
« Reply #5 on: 21 Aug 2021, 05:33 pm »
Greetings & Welcome to AC egeeks   :thumb:
sunnydaze
Re: Tube preamp
« Reply #6 on: 21 Aug 2021, 08:28 pm »
I'd take a look at YS Audio / Audio Experience.
http://www.ys-audio.com/e_exp.htm
I own an older version of the Balanced (level 3).  Fairly well built with minimal parts and functionality you don't typically find at the price.  Sounds good and IMO it's a VG value.  I see them used at below your budget.
The Symphony (level 2) is the next model down and the new price is within your budget.  I hear good things about it.  Worth looking into.
Edit:   the Eastern Electric MiniMax is also a great choice at about $500 used.  Very musical and allows for fun tube rolling.  Years ago owned the version with Tom Tutay mods, loved how it sounded.  Sold it d/t lack of remote volume control.   :roll:
