Oliver Sayes 300b custom amp
0 Members and 1 Guest are viewing this topic. Read 1261 times.
drhoon
« on: 17 Aug 2021, 07:53 am »
Description from Oliver:
Power supply uses 4 x 6au4 rectifiers in a bridge configuration with the full output powering the 300b with choke input and half the output for separate supply the 12v6 driver and 12j5 input tubes.
For the signal section input tube is 12j5 (these go in the 2 centre sockets at front) which is direct coupled to 12v6 driver tube, this in turn is interstage coupled to the 300b.
10.5 watt
Heyboer power, electaprint output transformers with lundahl interstage.
Gold lion 300b, NOS sylvania/RCA rectifier and input tubes.
$2700 local pick up for now., Tampa
Will split shipping if desired.
