I just upgraded my AV system a whole bunch.
0 Members and 1 Guest are viewing this topic. Read 2462 times.
avahifi
    • http://www.avahifi.com
« on: 15 Aug 2021, 04:20 pm »
I installed a pre-production model of our new Digital Preamp and a pair of our new M225 balanced mono amplifiers.  These replaced an older Vision solid state preamp with a built in DAC and a very much older Fet Valve 400 power amp,
The sound is now spectacular with the huge, deep sound field of my reference system and outstanding resolution and range.
The speakers are an early production pair of Salk HT2-TL floor standing models.  The speaker have kept up with the other improvements even better then I would have suspected.
There is another interesting reason why my AV sound is so good in addition to the upgraded audio components.
A key is my use of a Monoprice HDMI splitter in the system.  This little box allows remote switching between four HDMI inputs, but its real secret is it also has a SPDIF coax digital output.  I feed my coax input cable to the Comcast cable box as usual, but the HDMI output of the Comcast box goes first to the HDMI splitter and then on to a LG hi def TV HDMI input. The unadvertised feature of the little splitter box provides a pure digital audio output. The digital audio output from the Monoprice unit goes directly to a digital input at my Digital Preamp.  This bypasses all the lower quality D to A converters both in the cable box and in the TV set itself. It provides an unprocessed digital signal before anything else can screw it up. This works with my Apple TV box too.
I also feed a digital out from my Blu Ray player to the digital preamp. I could connect the digital output from my VCR too if I could remember how to set its clock.
The Digital Preamp then feeds the pair of awesome M225 mono amps and the Salk speakers.  Sonic bliss.
The Comcast music channels now come alive and so do the movies.
Got a big high end surround sound system?  What you really need is five of our M225 amps. Instant world class sound.
Frank
jtwrace
    • TIPP YouTube Channel
Re: I just upgraded my AV system a whole bunch.
« Reply #1 on: 15 Aug 2021, 05:07 pm »
What's the difference of using this box rather than just optical out from the TV to a high quality dac with optical in?
Early B.
« Reply #2 on: 15 Aug 2021, 08:09 pm »
Did you say, "VCR?" :o
avahifi
« Reply #3 on: 15 Aug 2021, 08:51 pm »
More conversion processes required.  First strip digital from video in TV, then convert digital to optical in TV, then convert optical to digital at DAC.
Too much monkey motion.
Frank
strat95
« Reply #4 on: 10 Sep 2021, 06:40 am »
Frank, can you kindly provide a link the the HDMI splitter you are using?
Thank you,
T
avahifi
« Reply #5 on: 10 Sep 2021, 09:30 pm »
The Monoprice HDMI splitter I use is several years old and long out of production.
Frank
Jonathon Janusz
mr_bill
« Reply #7 on: 11 Sep 2021, 04:52 pm »
Looks #3 has a coax out and #1 has a Toslink out
avahifi
« Reply #8 on: 11 Sep 2021, 06:22 pm »
It looks like that #2 or #3 would work fine, depending on how many DMMI outputs you need.
Only catch I noted with their owners manuals was that #3 does not show any included remote sender.  Confirm that before you order and let me know.
I could use a new one too but it must have remote.
The older one I have now causes confusion between the Monoprice and my smart TV.  Switching my tv from cable to UTube sometimes makes the HDMI switcher change to a different output channel. Then the smart TVs tries to switch too. This causes the switcher to turn off. Unauthorized ghostly behavior.
If I orders new one I will just get the single HDMI version.  I have plenty of spare HDMI inputs on the TV anyway.
Frank
Frank
