Any New Holo😐 Spring 3 Owners Here?
0 Members and 1 Guest are viewing this topic. Read 1909 times.
Kw6
« on: 11 Aug 2021, 05:44 am »
Please share your experience and what you have tried and what was the deciding factor which made you go with Holo Spring? Thanks!
ACHiPo
Re: Any New Holo😐 Spring 3 Owners Here?
« Reply #1 on: 11 Aug 2021, 08:45 pm »
I ordered the Holo May KTE and am delighted.  From reviews the Spring is also good, just not quite as smooth and resolving as the May.
kmmd
    • Systems
« Reply #2 on: 12 Aug 2021, 08:37 pm »
The Holo Audio Spring 3 DAC looks like a stepped down May without the separate dual mono power supply.  The 3 different levels appear to be similar offerings as those for the May.  However, you can order it with the optional preamp module which will allow you to go straight to your amp.  It looks to be a promising DAC.
Congrats on your May KTE ACHiPo.  You’ll love it.  I’ve had mine since January.  Be patient and allow it to break in over time.
Happy listening!
Kw6
« Reply #3 on: 21 Aug 2021, 06:12 pm »
Achipo
So did you get the dac yet?
Kw6
« Reply #4 on: 21 Aug 2021, 06:13 pm »
Achipo
What dac did you use before?
